I got my pulley set in the mail today (crank and alternator set). Me and my dad installed it and I had a few questions. First, can changing the pulleys mess up the timing at all? We checked the timing after the installation and it is at 16. Also, should I be worried about the alternator? At idle, the needle is a line or two below the 13 mark. My dad thinks the alternator is not getting enough charge because of these pulleys, but I don't think their was any difference before with the original pulleys. So what do you think? Is this ok for the alternator? Thanks!
ASP Pulleys
ASP Pulleys
<a href=\"http://home1.gte.net/res07t9s/index.html\" target=\"_blank\">My 1991 Firebird - 3.1L V6</a> with custom K&N CAI, Flowmaster, Sony CD, MTX 4-ch amp, 2 MTX 10\" subs, Sony & Polk speakers, Eagle Wheels<br /><br /><a href=\"http://home1.gte.net/res07t9s/index.html\" target=\"_blank\">My 1997 Firebird Trans Am</a> with T-Tops, Panasonic CD, Alpine Speakers, MagnaFlow Exhaust, and Lingenfelter CAI.Tags: None
timing is controlled by the timing chain under the front cover. really don't have an answer as to why the timimng advanced,.....unless it's spinning faster..did your engine rpm change any?
As for the alt, one of a few solutions:
1. This is normal for underdrive pullies. Rev the engine. some alts need to get to a certain rpm to "excite" the voltage regulator to kick in.
2. This is normal, & light should go away under higher thana idle rpms. If you have a "loud/above average" sound system, either install a boomer cap or put origonal alt pulley back on.
The reason for the light coming on is that now the alt is sspinning x% slower than normal, and not fully getting up to the voltage needed.
3. Get a higher output alt. this is usually about $160 for a 140amp alt, but should get rid of that pesky low voltage light.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
I just purchased some JET Performance pulleys, they are in the mail. I hope I dont have any problems with them. I will purchase the higher amp alt. Where can I find one? The largest the local autoparts store carries is the 105amp.[*]<b>Car: </b>1991 CHEVY CAMARO RS<br />[*]<b>Engine: </b> 3.1lt (191ci) V6 - MPFI<br />[*]<b>Stereo: </b> Alpine 7995 H/U | Eclipse 21000 EQ | BOSS IQ 3000w Amp | Crossfire AB 400watt Amp | 3 AudioBahn 12\" D/V Subs | Planet Audio 4x6\'s & 6x9\'s
Ok, thank you 3.4 slow to go for the information. I drove it quite a bit today and it seems to run well.<a href=\"http://home1.gte.net/res07t9s/index.html\" target=\"_blank\">My 1991 Firebird - 3.1L V6</a> with custom K&N CAI, Flowmaster, Sony CD, MTX 4-ch amp, 2 MTX 10\" subs, Sony & Polk speakers, Eagle Wheels<br /><br /><a href=\"http://home1.gte.net/res07t9s/index.html\" target=\"_blank\">My 1997 Firebird Trans Am</a> with T-Tops, Panasonic CD, Alpine Speakers, MagnaFlow Exhaust, and Lingenfelter CAI.
I have had a sligt problem with this set.....
When its really hot out I'll drive with the A/C blasting, the CD player on, and I'm in stop and go traffic for about two miles to work. This wouldn't let the battery recharge, so after a few days of this I needed a jump. Then I took it on the freeway for an hour and it was fine after that.......
Time for some dyno numbers Brandon. [img]graemlins/thumbsup.gif[/img] :D
