if you do...... get everything, I mean EVERYTHING from donor car. best if donor car sitting beside your car. don't forget ecm, pedal brackets, clutch cyliners..etc.....
best non-auto for car....6-sp w/skip shift adaptor
same goes if putting V8 into 6er car
question: WHy not just go for te 3.4 swap? Cheaper & easier ;)
[ January 03, 2003: Message edited by: 3.4 slow to go ]</p>
2013 Ram 1500 Big Horn
94 comero 3.4
I just reused the intakes, distributor, & sensors. I am even using the O2 sensor right in the pass side exhaust manifold. The 3.4 have 2 O2 sensors, 1ea in the manifolds. When I get the headers put on, I'm gonna have to have relocate the sensor back into the custom Y-pipe.
I got my 3.4 for $210 & a 12 hr road trip to get it. It was $200-$300 cheaper that way than a local one. Also the salvage yards. stick w/93-95 3.4 f-body only. I've seen average ones going for about $500-$600. also check e-bay, there usually is a company from FL selling them.
94 comero 3.4
I did the swap last month...and yes the T5 is an overdrive trans.
The total swap cost me around $600. I installed the pedals and master cylinder first, which took about 2.5 hours. On a different day, I pulled the trans, cut the shifter hole and installed the T5 all in about 7-8 hours.
As far as difficulty, I did my swap on a lift so it was easier. I've never pulled a trans before this and it wasn't that hard but it's a bit intimidating.
I was quoted $2700 for a shop to do it on my 85 2.8L.
ITs rough...
If you do do a v8 swap I woudl do t56(6-speed)swap, and I would do it all together.
A t-5 won't withstand the torque form a 350, you woudl be much better off in the long run with a t56, and there are swap overkits you can buy, I haven't searched for one in a long time but they are out there.
As for 3.4Ls, I have seen some as chaep as $200 and others as mcuh as $3-500.
