3.4 question - FirebirdV6.com/CamaroV6.com Message Board
3.4 question
  • 3.4 question
    New guy here.
    I posted this on www.thirdgen.org and was wanting to see if I could get a few more "advanced" replies here.
    I have a 2.8 86 Camaro (A4), 3.42 gears. No power options, smog, or A/C, all the free mods and some goodies.
    Looking at a 3.4, power pak heads with the 1.8 valves from www.supersixmotorsports.com, undicided with a cam but may go with the cam that is in the package, full port on the 2.8 intake manifold and the exhaust manifolds, maybe a chip, ASP crank pulley, keep the accel ignition, run a custom hooker exhaust with a high flow O/R y-pipe, do a little more weight reduction and leave it at that.
    I am a college guy so I can not afford an L98 IROC with the insurance or an LS1 car with the insurance. But I have the knowledge (in aviation maintenance school and done with automotive) and money to swap in the 3.4.
    Any thoughts on this combo? I think it will be good enough to pass the 200rwhp mark with the right cam to work with the heads but I would like some other opinions.
    Thanks
    David
    Black 96 Z/28, A4, T-tops, tint, 2.73 LSD, Kenwood.<br /><br />Previous Camaro: Bright white 86 Camaro, MPI 2.8 A4 3.42, tint, Z-28 wheels, a few goodies.
    Welcome [img]graemlins/thumbsup.gif[/img]
    you may just have to settle with an Project 85: 2.8 bird answer [img]tongue.gif[/img]
    I checking into the head flow numbers right now, but I beleive to fuly apreciate the increase i power (and to justify the increase in price) of the larger valves, a power adder should be added. I'm gonna stick w/the cai on my set up & see about finally installing the MSD when I get back. Yo apparently now have only one choice of headers &lt;I got the CHC ones :D ;) ) Maybe see about Karls "extrude honing" of the intake manufolds (if you can afford it) Keep the accel stuff. Save the chip for last. For exhaust, be different....get a Raven exhaust. I've heard one on one of the fellow REDLINEVSIX members cars. sounds good.
    which way will you go w/the 3.4 install:
    v1: Karls
    v2: mine
    or
    v3: Dales?
    Also, check out this sites LOUNGE, I think you will enjoy it, especially w/the coming crackdown at the thirdgen site ;)
    [ January 22, 2003: Message edited by: 3.4 slow to go ]</p>
    2013 Ram 1500 Big Horn
    94 comero 3.4
      When it comes to exhaust I am into performance not the sound [img]smile.gif[/img] , I am looking at buying a spar 2.8 manifold and having some fun with them and the exhaust manifolds, I may combine your swap, Keds, and Dales, I will have about 5 other guys over here so we will get it done real quick :D
      Whats with the crack down, is it here or at thirdgen?
      P.S. here is the dyno numbers on the stage 1 package 146rwhp at 4600 RPMs 186rwtq at 3400-3500 RPMs.
      He has a few nasty ignition and fuel problems and this was on a almost stock 5 speed car :eek: , Ill have the stage 2, 1.8 valves, more porting, much nicer cam :D
      [ January 23, 2003: Message edited by: 86camarodriver ]EDIT: I just re read the power pak thread, those numbers are BEFORE the power pak :eek: :eek:
      [ January 24, 2003: Message edited by: 86camarodriver ]</p>
        I have the 2.8 exhaust manifolds if you need them. "Crackdown " in the .org site, you know, about keeping it strictly tech. but then, there has been a lot of flaming going on. Also have spare upper manifold w/tb not using. make me an offer ;)
        Combining all of our versions? how so?
        for the uninitiated:
        Karl, aka KED85: 2.8-3.4 swap, reusing 2,8 intakes, distributer, & front timing cover so he can reuse 2.8 accessories.
        Me, aka Project: 85 2.8 bird: 2.8-3.4 swap, reusing 2.8 intake & distributor-but keeping the 3.4 accessories on.
        Dale, aka Dale [img]graemlins/dunce.gif[/img] [img]tongue.gif[/img] : He's doing a complete 3.4 swap including the DIS setup & ecm. Only he needs to reuse the old fuel rail due to the fuel line hook ups.
        94 comero 3.4
          Well I pan to use the V-belts so 2.8 power steering, water pump, and alternator, I do not want to deal with the head ache of a 3.4 swap with the 3.4 ECM, wiring harness, and 3.4 intake LOL. I will use Karls tech guide and use the 3.4 distributor, so most of Karls stuff just customise some stuff. How much for the manifolds?
          Free???? :D [img]graemlins/evilgrin.gif[/img]
            free w/pickup. otherwise pay s&h (to include packing material/box.
            btw, I'm reusing the 3.4 belt setup, just hooked the powersteering lines to the new pump. no headache except finding the correct belt legnth due to the a/c delete. a 3.4 w/open manifolds sounds....interesting
            94 comero 3.4
              I really REALLY have no time to drive to Downtown INDY let alone Dayton LOL
              E-mail me your address (rf805@yahoo.com) and I will send out the check.
              After finding out the dyno numbers are only with a ported intake and exhaust I really think I might get 200rwhp. I also found a place that sells chips for 100 ish $$$, 100 more for custom tuning.... [img]graemlins/burnout.gif[/img]
                dude, you know you're gonna have to share the wealth on the chips ;) . Did you want the upper intake too, or just the exhaust manifolds?
                94 comero 3.4
                  :eek: Ill take anything you can get me :D , Ill just have to find someone to sell just the lower intake LOL!!!!!!!!!!!!, Im really tired right now so Ill look for that site Sunday, I think it was MAC headers site, but I don't know.
                  Its about 4 above 0 here now, just got home from work, took the back roads, our cars LOVE the cold air :D [img]graemlins/toto.gif[/img] [img]graemlins/burnout.gif[/img]
                    I also have the 2.8 heads, if you want them for a core, ;) ;) , for the supersix heads. But wonder how much shipping for those would be?
                    94 comero 3.4
                      A TON LOL, they don't know if they will need them or not, if they do or don't they shipping charge may not be worth it. They said 20-50 bucks if they don't need them. [img]graemlins/fluffy.gif[/img] [img]graemlins/toto.gif[/img]
                        I think it woudl be a sweet setup...
                        as for the guy doing the complete 3.4L setup I woudl advise against it or go for a 93 ECM setup... 94-95 the chip is soldered into the circuit board, so none removable.
                          Dale is swapping the 3.4 motor into a 93 S-10 show truck & kicking the dead 2.8 to the curb.
                          94 comero 3.4
                            I may have to bug Dale for his distributor and things :D
                            Thanks for the input mustangeater
                            From fasttoys.net in the thirdgen electronics section
                            I am sure they can make one for the 2.8 computer......
                            Superchips tunes the engines to run on 92 octane gas and typically achieves 10% more HP and 15% more torque. Engine reponse is dramatically improved and the 0-60 time and 1/4 mile times willd drop substantially. Automatic transmission shifts are firmed up as well. 30 day money back guarantee. Custom tuning available for cams, superchargers, NOS etc.
                            Superchip For 82-92 Camaro/Firebird
                            189.99
                            CUSTOM
                            Custom Tuning
                            100.00
                            By the way, what is everyones opinion on a 2.8 throllte body port with the power pak set up?
                            I think it would be a good idea.
                            [ January 26, 2003: Message edited by: 86camarodriver ]</p>
                              <blockquote>quote:</font><hr>Originally posted by 86camarodriver:
                              [QB]By the way, what is everyones opinion on a 2.8 throllte body port with the power pak set up?
                              [QB]<hr></blockquote>
                              I think it woudl be a great idea... I know on my 3.4L one of the problems is the motor cannot breathe... this is on a 4th gen but the 2.8L is sort of similar but not as strangled as a 3.4L intake in my opinion.
