i was looking on 3rd gen resource and saw some cross drilled brakes for the front and rear used. i was wondering if i could swap the disc brakes on the front and drums in back for the cross drilled ones and how expensive would this be?
brake question
how can you be sure they're not warped? and if so, how can they be machined?
it's easiest to get the rear from a donor car, & snag the master cylinder & proportioning valve from it too. also inspect the parking brake setup. I believe it's different than the drum set up.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
