stripped oil plug - FirebirdV6.com/CamaroV6.com Message Board
stripped oil plug
  • stripped oil plug
    i was trying to do u tune up on my ride when i found that my oil plug was stripped i tried that gator grip wrench tool from walmart for 14 bucks, and it worked like a charm. so remember befor u think about cutting ,chiseling,vice grips or an auto shop try that.just in case anyone else runs into that problem. [img]graemlins/thumbsup.gif[/img]
    3rd gen v6 camaro<br />VENOM VI member
    What did you use to replace it? A self tapping replacement or that FRAM "fancy" remote/clean erl drain plug do-hiky?
    2013 Ram 1500 Big Horn
    94 comero 3.4
      i used that fram sure drain thing. hopefully my oil changes will go alot quicker now.
        Fram Sure drain works great, but I took a zip-ties around the tubing and the collar of the drain attachment, as when it gets covered in oil it tended to slip right off. With a Zip-tie it stays in place like Fram *should* have made it.
        <b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
