Results from the E-Check Nazis - FirebirdV6.com/CamaroV6.com Message Board
  • Results from the E-Check Nazis
    Tampering:
    Cat Convertor.........................Present :rolleyes:
    Presence of gas cap................Pass :rolleyes:
    Emissions:.............Reading................Limi t............Result
    HC.........................718.9.................. ...157............Fail
    CO.........................13.34.................. ....1...............Fail
    CO2........................6.32................... .....................N/A
    Gas cap passed pressure check.
    This is w/the MSD Box. During the test, done around 25mph, black smoke going out of the tail pipes [img]graemlins/dunce.gif[/img] . I still have to change erl, erl filter,plugs. I'm going to see about connecting the )2 sensor wire to the one in the T-pipe & see if that all makes any differenc.
    BTW, Got the title today :D [img]graemlins/fluffy.gif[/img] [img]graemlins/fluffy.gif[/img]
    [ August 02, 2003: Message edited by: 3.4 slow to go ]</p>
    2013 Ram 1500 Big Horn
    94 comero 3.4
    OK, after driving it about 25-30 miles saterday, including getting the title & e-check :rolleyes: , I drove it home parked it. About 5 hrs later, a friend from PA came over & I wanted her to hear the bird now that it has an exhaust, & not open manifolds any more. It cranks, & no start. I was liek wtf? :eek:
    ********HINT************
    I was able to diagnose & got lucky w/a fix. The fuel pump relay harness is the same as the A/C relay harness. I do belive they are the samew relay, as I am now using the A/C relay for the fuel pump. ;)
    94 comero 3.4
      I failed visual because my homebrew intake wasn't sealed to the hood... whatever. You know what you need? You need a '91 bird with a 3.1 that runs like a dream and needs a good home ;)
      1995 Nissan Hardbody King cab XE, 5-speed, 4 banger<p>Looking for the right Camaro...
