ive heard about installing the 2030 series crane cam. some say that it doesnt come with a certain part on the end of it that is needed for mid 94 to 95. is this true? and if so, what is it? if i do install this cam, will it be compatible with the ECM in an 88 camaro?
cam question
the 2030 cam doesn't have the tang thing for the cam position sensor needed for teh 93~95 DIS. Check out the GMPP catalog. last time I checked, last year, they had a cam kit w/more lift & shyt & lifters for $118. ;) [img]graemlins/thumbsup.gif[/img] [img]graemlins/thumbsup.gif[/img] I think it was the 3.4 HO cam kit.
[ November 10, 2003: Message edited by: 3.4 slow to go ]</p>1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
Yep, that's it. Or you can experiment a little and try the Crane 250801. LSA 112, Lift 460 on int,ext and 290/300 adv. duration. It will take a bit of tuning to get it running right but it will be good. [img]graemlins/burnout.gif[/img]
going by the holy book haynes,
w/1.5 rockers (stock I belive)
intake: .393
exhaust: .409
3.1 got bumped up to
intake: same
exhaust: same [img]graemlins/slap.gif[/img]
edit:
here's the kit:
12364059 Camshaft Kit
Applicable to all 1980-94 Chevrolet 60º V6 (2.8-liter & 3.1-liter) engines, this performance-oriented camshaft kit is designed to significantly improve mid-range torque and horsepower without sacrificing idle quality. The basic RPM range is 1500-4500 with 6500 RPM attainable using proper valve springs. Cruise RPM is designed for 2200-2600 RPM, and a compression ratio of 8.0-9.5 to 1 is recommended. This kit is not legal for pollution-controlled vehicles. This camshaft kit is designed and manufactured by Crane Camshaft Co.® for GM Service Parts Division. The kit includes (1) camshaft and (12) tappets. The duration at .050 lift (intake/exhaust) is 204º/216º, while the value lift is .427"/.454". Lobe centerline is 112
[ November 11, 2003: Message edited by: 3.4 slow to go ]</p>1978 Formula 461 in progress of being built :rock:
94 comero 3.4
it says its not legal for pollution controlled vehicles. does that mean any with emissions or just california regulations? also, can i run it with the stock valve springs or do i have to get the ones listed?88 camaro 3.4 M5<br />15.9 @ 83mph, traction needed desprately
I would go ahead & upgrade everything while the cam is out. New springs, retainiers, check pushrods for straightness. Even look into new rockers, roller tip or full rollers if you can swing the $$$$. Personally, I'd take that whole pollution controll thing as a "suggestion only" IF your car is properly uned, it shouldn't make that much of a difference.1978 Formula 461 in progress of being built :rock:
94 comero 3.4
