Too all of you 2.8ers out there... - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    <blockquote>quote:</font><hr>Originally posted by Jerriko:
    A couple of weeks ago, I got these results out of my car at the strip:
    -15.67 @ 85.1mph
    <hr></blockquote>
    Nice run [img]graemlins/thumbsup.gif[/img] stock/lightly modded 3.8 times right there
    <b><a href=\"http://members.cardomain.com/redaudiomobile\" target=\"_blank\">1998 Red A4 W68 Firebird</a> <br />10 PSI <a href=\"http://www.procharger.com/superchargers.shtml\" target=\"_blank\">ATI Procharger</a> <a href=\"http://www.imagestation.com/picture/sraid81/pb4b6eeb42f57d06389e3ac12068e7a67/faff97eb.jpg\" target=\"_blank\">Intercooled</a> </b> <br /><b>~~</b>Borla catback, <a href=\"http://www.imagestation.com/picture/sraid91/pf2d3103bcf8fef15756e8ec41c695d6c/fa6c671d.jpg\" target=\"_blank\">3” Catco Cat</a>, <a href=\"http://www.imagestation.com/picture/sraid91/p8e41ca8b59b95024690456cd102f7c65/fa6c672a.jpg\" target=\"_blank\">Pacesetter Ceramic Coated Headers</a>, 3.73 gears, Zexel-Torsen<br /><b>~~</b> <a href=\"http://www.imagestation.com/picture/sraid91/p5f73f1370269f5c5334b6d8cbbeec4d1/fa6c6712.jpg\" target=\"_blank\">K&N Air Filter</a>, <a href=\"http://www.imagestation.com/picture/sraid91/p9da8e4ea1855acbbfb5067bc9762b9b6/fa6e6fe4.jpg\" target=\"_blank\">TSP Clear Lid</a>, <a href=\"http://www.imagestation.com/picture/sraid91/p4f9c7720261bdd59f9e55275f022ef8d/fa6c6706.jpg\" target=\"_blank\">SLP CAI</a>, 160* thermostat, <a href=\"http://www.imagestation.com/picture/sraid81/pec71087de994f110a77b62a06ab5b77d/faff953c.jpg\" target=\"_blank\">Autometer C2 Gauges</a><br /><b>~~</b> <a href=\"http://www.imagestation.com/picture/sraid88/p70f4e24cb84ebce6e87577a1086b47a0/fa901042.jpg\" target=\"_blank\">Katzkin Black/Red Leather Seats</a>, <a href=\"http://www.imagestation.com/picture/sraid91/p768a90d0c13e9740c0d353ac1b322e6a/fa6c6717.jpg\" target=\"_blank\">Bilstein HD Shocks</a>
    • #17
      I went ahead and bought some Richmond gears (3.73). The runout on the old ring gear was .040". The tolerance is .000". But yes, some swapping will be necessary.<hr></blockquote>
      That should say .004". There's a big difference between 4 and 40 thousandths. And thanks.
      • #18
        I spoke with a representative from SLP today and he told me that when GM makes changes from year to year they will use overstock first and then switch to the newer parts. I have heard of GM doing this in the past and it would explain why some 89 F-bodys would have 26 or 28 spline axles.
        • #19
          what did they say if you have the 26 splines, just send it back?
          2013 Ram 1500 Big Horn
          94 comero 3.4
          • #20
            He said that you should verify your spline count before you order. I said that they should have put that inforrmation on the website so people knew that they may not have the right spline count.
            • #21
              -15.67 @ 85.1mph
              That's good enough for 3rd overall in the n/a 3.4L listing on the timeslip page. It should also be noted that this pass was made without my headers installed and the trans was getting funky with the 2-3 shifts at WOT. I think the trans is fixed now. On the dyno, it works fine. Hopefully, I can get one more chance at the strip this year to see how much faster I can get her. Don't take any **** from anyone with a 3.1 or 3.4!
              <hr></blockquote>
              wowo what mods? my 2.8L I think only hit 17s, I wasn't ath big into cars, but then I got into it with my 3.4L.
              Some nice runs!
              jsut curious what took it that far, a freidn of mine has some 15 second passes in his 2.8L, IT ink they have mroe ptential hen 3.4L 4th gens [img]smile.gif[/img]
              • #22
                BTW submitthat sh|t!
                and hit the track, those 15.650 times, are not hard to beat just need a little time, jsut don'trun fastre then a 15.457 ;)
                • #23
                  I submitted the time a couple of weeks ago. The mods can be found at my website but here's the quick list:
                  -CAI w/ K&N
                  -P/P throttle body and upper/lower plenum and intake
                  -MSD 6a ignition, MSD blaster coil, Accel 8.8 Race wires, NGK plugs
                  -custom dual exhaust w/ H pipe and dual Dynomaxes (2.5")
                  -Rebuilt 700R4 w/ shift enhancer and shift kit (Transgo) and 3300 stall converter (TranStar) w/ dual trans coolers
                  -3.23 LSD rear end
                  -manual fan switch
                  -manual 7th injector switch
                  The tracks have been closed for the rest of the season in my area. So more runs will have to wait til next year. The best thing about the mods is that I still haven't installed the Pacesetter headers that I have modified for my car. I am installing a 3.4 next spring and a rebuilt rear end w/ 3.73 richmond gears and an Auburn LSD.
                  • #24
                    how'd you rig the cold start injector?
                    94 comero 3.4
                    • #25
                      The 7th injector (cold start) doesn't pulse like the other injectors. It's either on or off. The ecm controls the ground. I just spliced into the ground wire and attached it to a toggle switch. Instant fuel. Best thing about the intake setup with the cold start injector is that that is a perfect place to install a dry NOS setup. It will supply every port and help cool off the intake at the same time.
                      • #26
                        Because I knew that I would forget some of the mods:
                        -TB coolant bypass
                        -Custom trailing arms (tubular)
                        -ASP underdrive pulleys
                        -Adjustable fuel pressure regulator
                        -SFCs
                        -KYB struts and shocks
