<blockquote>quote:</font><hr>Originally posted by Jerriko: I think you could fit an inline six between those motor mounts.
Jim
:rolleyes: <hr></blockquote>
I think the 4.2 I6 would be the next step once you're done with the 3.8. It would be cool to have one, but I think my mom likes having an engine in her car too.
OK, got the cluster "wired" for now, here's what I got:
Volts- work, but I didn't have that wire from the alt hooked up, hrmmmmm
Oil- Pegs when key in "on: position. Not sure if this is because it's not acytually hooked to anything or not.
Water- Pegs when key "cranked". See above for question on it
Gas- Didin't move, but it may be accurate. Will check level w/lighter after post
Seat Belts- good
Brake- Light stayed on, not sure about this.
Turn signals- Worked, didn't screw that up.
Hi Beam Indicator- see above.
Gonna have to wait for Speedo & Tach for when the engine is ready to run & I figure out which wires from the 3800 harness they actually are (I haven't rechecked that yet [img]redface.gif[/img] )
[ January 03, 2004: Message edited by: 3.4 slow to go ]</p>
2013 Ram 1500 Big Horn
94 comero 3.4
3800 back out, in preparation of car being pushed out of garage to get 3.4 out (having the car be more than 400lbs lighter is a big help :D )
While out here are my plans:
1. Rust control & engine bay prep/paint
2. Finish painting block & pullies
3. Gaskets for tb, valave covers, upper intake & replace rear main seal while out (if you see this gasket/seal, it's reallt f'd up compaired to what th 2.8~3.4s have)
4. Replace log exhaust manifolds w/tubular ones (header like)
5. Get 4th gen radiator for better hose placement.
6. Finish off a/c delete box/pcm shelf support.
7. Order VATS bypass box
8~infinity finish off the little stuff.
I'm kinda hoping to get car done by AIS3, but I'm not sure.
Also will be out of the game for 2wks, going to school in Biloxi. mmmmmmmmmmmmm, Warmmmmmmmm (at least compared to here)
Not really a big list, and about 80% of all the wiring has been identified.
94 comero 3.4
Quick reply update: Engine & tranny are mated & in the car. I have an exhaust/suspension issue which may hold up the project (maybe) but I'm a gonna start the home stretch now [img]graemlins/banana.gif[/img] [img]graemlins/banana.gif[/img] [img]graemlins/banana.gif[/img] [img]graemlins/banana.gif[/img] [img]graemlins/banana.gif[/img] [img]graemlins/banana.gif[/img] [img]graemlins/dj.gif[/img]
94 comero 3.4
well, it cranks, but runs yet. Gotta check fuel level, fuel pressure, spark. Also, I belive the reason for the fuel pump continuously running/priming (either due to lack of fuel, or because I was runing a hot wire directly to it, no relay or ecm input). Ahhhhh, the wonders of engine swaps :rolleyes: :(
94 comero 3.4
Is there anyway that you can straighten out the throttle body? I saw pics somewhere of someone else who did the swap that you are doing but they run air ducting to the TB in its current position and it looked really restrictive.
the 84 camaro? I'm keeping the angled tb & maifold to ensure it clears the hood. CAI will be like the 3.4 style, only on the drivers side. PVC initially, but planning on getting something more blingity bling later.
94 comero 3.4
