34, heres a question for you about your swap... - FirebirdV6.com/CamaroV6.com Message Board
  • 34, heres a question for you about your swap...
    Did you ever have the chance to compare the flexplate off of the 2.8 or 3.4 with that of the 3800? I am wondering because I am looking for an aftermarket flywheel for the manual setup with my 3.4L. I need to know if the bolt pattern on the 2.8/3.4 flexplate is the same as the 3800 flexplate. I have having problems finding a good flywheel for the 3.4 and am thinking since the diameter of the flexplates should be the same but I am not sure about the bolt patterns.
    Thanks,
    Jim
    THe bolt pattern on the convertors looked 99% the same, even held them up to each other. Big question you need to find out is the tooth count on the flexplates.
    2013 Ram 1500 Big Horn
    94 comero 3.4
      Actually, the bolt pattern I am looking for is the on the crank.
