97 rear end in a 84z? - FirebirdV6.com/CamaroV6.com Message Board
  • 97 rear end in a 84z?
    Will a rear end from a 1997 camaro fit on a 1984 camaro z28?
    http://www.bowtiev6.com/
    I will say yes:
    I haven't read all of this in a few, but you should be able to reverse engineer the following http://www.thirdgen.org/newdesign/tech/4thgenrear.shtml
    2013 Ram 1500 Big Horn
    94 comero 3.4
      it will bolt up yes, but its wider, and you will need to run 4th gen wheels (large spacers are needed in the front to make 4th gen wheels work on a 3rs gen)
      Ryan
      1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
        From what I here, they will bolt up no problem but the wheels it sticks out I think 2 in. on either side
          your right, thats why you need to run 4th gen wheels. teh bolt pattern is the same, but offset os way screwed up.
          Ryan.
