So I grabbed my uncle's timing gun and decided to see if my timing was the reason my idle was so shaky. I get the gun plugged in and immediately notice the problem. My motor (3.1) was advanced about 19*! Seeing that it should be closer to 5, I got to workin on the distributor bolt, the most annoying fudgin thing in the world.
Using a box end wrench, not enough room to move the bolt. Using a socket wrench, we couldn't even get it on the bolt because the distributor plate did not allow much of a clearance.
After about 2 hours of trying to figure out what size bolt it was (because we couldnt get one on it to see if it fit), I went to the christmas presents and grabbed the stubby wrenches I had purchased for my dad. Because the head angles, we were able to get a socket on the bolt and FINALLY loosen it enough to adjust the timing.
Dad was a little peeved I was holdin out on him, but hey... He got a Christmas present a month early, so he was happy.
We got the advance back to 5* and tested it out. :D S m o o t h e s t idle I've ever seen on this car. So this is where the story turns into a question. How did the motor advance itself that much? What can wear that'll effect the timing? I thought it was only the timing chain that could stretch a little, but even then it wouldn't give much more than a degree or two.
I'm sorry for sounding like a twelve year old, but I'm really happy I was able to fix this, and I want to learn why it got that bad to begin with. Thanks in advance.
