performance? - FirebirdV6.com/CamaroV6.com Message Board
performance?
  • performance?
    i have a 992 camaro 3.1L and was wondering if anyone else has one that they are trying to build up and also if they have any info that could help out with my project i would be orever grateful. thanks
    Josh<br /><br />92camaro 25th anniversary<br />Exhaust,audio,soon to come supercharger,cam,headers
    Dynomax Makes a catback
    ASP makes underdrive pulleys
    K&N makes an air filter
    Pace setter makes headers (not smog legal)
    Crane makes cams
    Catco and Magnaflow make a high flow cat
    Search around Summitracing.com and SLPonline.com
      Forget crane, their cams are not that good. I bought one for the 3.4L I built. One of the exhaust lobes went flat after a couple months.
        Without the problems of smog you might stand a chance, the only thing I've found that remotely helps you get up to speed is nitrous.
          is the firebird 3.1 the same as the camaro 3.1
            yes
            2013 Ram 1500 Big Horn
            94 comero 3.4
              so all performance upgrades that are for the firebird 3.1 will work for the camaro 3.1
                Originally posted by 3.4 slow to go:
                yes
                  thanks
                    with 1 exception, comeros cain use the dual snorkel intake setup, birds caint.
                    94 comero 3.4
                      where can i get one of the dual snorkel intake setup at?
                        comaro dual snorkel intake
                        e-bay, or even junkyards. check out thirdgen.org tech articles for ram air w/this setup.
                        94 comero 3.4
                          cool thanks
                            how much power do you think that might add?
                              1hp if your lucky.
