Aluminum heads are especially vulnerable to warpage and cracking because aluminum has a much higher coefficient of thermal expansion than cast iron. Consequently, when a bimetal engine with an aluminum head gets too hot, the head tends to swell up in the middle, causing it to warp and blow the head gasket. If the engine has an overhead cam, the resulting misalignment in the cam bores created by the warpage can gall or seize the cam bearings, or even break the cam. Anytime you encounter a warped or cracked aluminum head, or an OHC head with a seized cam, chances are the damage was caused by overheating.
In some engines where the center exhaust ports are siamesed together, hot spots can develop in the head between the exhaust ports causing the head to swell so much it crushes the head gasket resulting in a blown head gasket. Replacing the head gasket may temporarily solve the compression problem, but unless the underlying cause of the elevated exhaust temperature is diagnosed and corrected, the replacement gasket may eventually suffer the same fate. Some aftermarket gasket manufacturers have gone so far as to develop special reinforced replacement gaskets for engine applications that have a history of crushing gaskets.
Too much heat in an engine can cause serious problems because heat causes metal to expand. The hotter the engine gets, the tighter clearances become until there are no more clearances left. Overheating can cause valve stems to gall and stick, and pistons to scuff and seize. So if you see either of these conditions when you tear the engine down, it’s a pretty good clue that overheating caused the engine to fail.
Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
