I just bought a 91 Camaro RS and found that it has rear disc brakes. I was very impressed as my other 91 Camaro has rear drum.
Upon inspection, I saw that the rotors are completely torn up from ware and tare and will need to be replaced.
I've been looking around at various sites trying to find replacement rear rotors, but I can only seem to find the front ones? Does anyone know where I can find these?
I have a dilemma... I found the brake rotors at a local vendor, but when I got them home I noticed that they are very different from the ones currently installed on the axle. This has led me to believe that this rearend was not orginally from this vehicle.
Is there a way to identify the vehicle that these rotors / calipers / pads belong so that I can find the correct replacements? [img]graemlins/stickpoke.gif[/img]
I did the search on a V6 RS rear w/discs. I don't see how the v8's would be different, but I have been known to be wrong. Any way to bring in the old rotors & compare at the parts store?
2013 Ram 1500 Big Horn
94 comero 3.4
I suppose I could take them into the store and do a process of elimination, I was just hoping for an easier way (i.e. a number somewhere on the parts to identify them, etc).
if the old rotors aren't too rusted over, ther should be some part numbers on the inside hub. Maybe a GM dealer might be able to tell you, but then they'll bytch & whine saying that since the car is more than 10yrs old we won't have any info on it :rolleyes:
94 comero 3.4
another question - The wheel spindle (I guess you would call it), the section with the lug threads attach to the axle, can that be replaced? The bolts are slightly bent and distorted.
cut toof the lugs, drill the center out of what's left. make sure you use the hardend drills specifically for drilling metal. It's like cutting thru butter
94 comero 3.4
parts store, tell them what you need. Also make sure you know if you have alloy wheels or not. best to take a couple of lug nuts with to make sure you get the right lugs (really only one style lug) but still.....
94 comero 3.4
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
