I have a 91 Camaro RS 3.1L v6 - When I start the car the rpm's immediately jump up to 3000 if not slightly higher and holds there for a minute and then drops down to an idle of 2000-2200.
I did a complete tuneup including: Spark Plugs, Ignition wires, Distributor Cap & Rotor, PCV valve, Fuel Filter, Air Filter, Oil and Oil filter. I purchased a new oxygen sensor, but I was not able to remove the old one, so I am going to have it done at the exhaust shop.
I checked all of the vacuum hoses that I could see and all seems to be in order. The only thing I can think of is the exhaust sounds really clogged up and rattles to high heaven. I plan to have the muffler and cat. converter replaced this weekend.
Also, I seem to have a problem with my oil pressure guage, when the car starts up, the guage will travel all the way to the right past the 80 mark, and after its ran for a minute it will stay move just between the middle mark and 80 - sometimes it will bouce around erratically.
Any thoughts?
Any thoughts?
