Sup folks, I'm going to be swappin my 89 Camaro RS 2.8 to my 90 Camaro RS. Never did an engine swap before. What do I need to disconnect wiring wise etc. etc. in order to get the engine out? Do all the wires go into 1 connector to the harness or will i have to disconnect every wire seperately? thanks for any help.
anything connected to the engine will need to be disconnected. make it simple for yourself and label everything. i know on newer cars no two connectors are the same so you cant mess up and put the wrong one somewhere it's not supposed to go but im not too sure about an older car. just label everything. if your not too familiar with engine compnents label everything by numbers. like take a piece of tape and put a number on the connector and the same number on where it plugs into. that way when you put the it in and connecting everything 1 goes with 1 5 goes with 5 and so on. makes it really simple. also take a lot of pictures so you have something to revert back to if you get lost somewhere. if you get stuck just ask. lots of knowledgeable people on here
'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Thank you. Yea I guess I will do that since I dont have too much knowledge of what ever vacuum line etc. etc. name is. lol. Maybe there's a pic out there that would number everything with a description. Gotta get a Haynes (think thats what its called) book from AID.
the 2.8, iirc, doesn't have any place for the knock sensor to go.
Other than that (which will throw a code or more) take the intake manifold assembly off the 3.1 and put on the 2.8. Now would be a good time to think about putting in a new rear main seal, timing chain, and waterpump. ALso verify that the connectors on the oil filter adaptor are the same.
Use new motor mounts, don't rush, and we're here for help.
edit: CamaroRSZ28SS, I'll be unavailable most of the week until friday for IM, sorry
