so im thinkin bout gettin my 83 running but it wont start...i was wondering what would keep it from starting? it turns over and evrything... 2.8 a3 v6 btw im gonna drive it till i get my new motor...
wont start
Re: wont start
Originally posted by 96greenmachineso im thinkin bout gettin my 83 running but it wont start...i was wondering what would keep it from starting? it turns over and evrything... 2.8 a3 v6 btw im gonna drive it till i get my new motor...
air, fuel, spark. one of those is missing.
let us know which & the rest should be cake.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
Re: wont start
If you think it is a fuel issue squirt a little gas or starting fluid down the carb (and I do mean a little). See if it fires. If not check cap and rotor for moisture since it has been sitting for so long. Check wires and plugs. Post your findings so we can give more help and ideas.
Re: wont start
replacement carbs for the vari-jet cain get expensive, and I'm not sure how to rebuild one (I've only done the quads).
edit: in no particular order, use your common sense, it's easire than retyping this.
Hose it down w/some carb cleaner & seafoam the gas. see if it'll clean out the carb.
also:
what do the plugs look like, is there spark, is it getting fuel, get some starter fluid.
What troubelshooting have y'all done so far?1978 Formula 461 in progress of being built :rock:
94 comero 3.4
