tire size - FirebirdV6.com/CamaroV6.com Message Board
tire size
  • tire size
    Ok I am getting new tires for my 1984 Z28 next week..Standard size is 215/60R15...
    Shoudl I stick with the standard size or go with something different/wider? If so, what size should I get?
    Also, what tires have you all had good luck with?
    Robin
    Re: tire size
    I had some Sumitomos on the bird when I upgraded to the 15" rims, worked good for what little the bird ran, and I now have khumos on the comero. I think I went w/225 60's on the bird. Try tirerack.com and experiment w/diff tire sizes. If you know the rim width you will have more tires to choose from.
    2013 Ram 1500 Big Horn
    94 comero 3.4
      Re: tire size
      235/60r15 up front, 255/50R15 in back :)
      \'97 Camaro M5 Y87 3.23 LSD, homebrew CAI, highfloCat, Flowmaster catback, Pacesetter headers, specstage3 clutch and aluminum flywheel, !egr, 2kW system.<br /><br />Possible L67 bottom end w/ abbott heads and a turbo in the works... gotta do more homework
