What is needed for a 3100 to 350 tpi swap? - FirebirdV6.com/CamaroV6.com Message Board
  • What is needed for a 3100 to 350 tpi swap?
    What all will be needed for a 3100 to a 350 swap....to keep it as cheap as possible....everything is stock and its a 5 spd tranny in it now..
    Re: What is needed for a 3100 to 350 tpi swap?
    first, i'm almost positive you have a 3.1 (the 3100 is different)
    3rd gens are pratically free right now, find a cheap V8 car and use it for parts
    you'll need a V8 bellhousing, kmember at the minimum
    1999 Camaro Z/28
    1973 Firebird Formula
      ya whichever motor it is.....i was checking on it for a buddy
        k-mbrs are they same, from 4cyl~8cyl, just need to look at th emotor mount holes. I think I have a some threads of when I dropped in the 305.
        2013 Ram 1500 Big Horn
        94 comero 3.4
          so really all you would need is a new tranny?
          1999 Camaro Z/28
            tranny, front springs, radiator (3.1 can be used, but your call), new guage cluster (same yr preferrably), new fuel pump, and the engine harness/ecm for the tpi.
            short list of course
            94 comero 3.4
              yea i knew the actual 'list' was a long one but the "minimum" is less than i expected i guess
              1999 Camaro Z/28
                also remember that the 350 never came w/a 5spd from the factory, so if you have a built up one, nake sure the tail housing is the vss type, not the speedo cable, as it will create fewer headaches.
                94 comero 3.4
