What all will be needed for a 3100 to a 350 swap....to keep it as cheap as possible....everything is stock and its a 5 spd tranny in it now..
What is needed for a 3100 to 350 tpi swap?
Re: What is needed for a 3100 to 350 tpi swap?
k-mbrs are they same, from 4cyl~8cyl, just need to look at th emotor mount holes. I think I have a some threads of when I dropped in the 305.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
tranny, front springs, radiator (3.1 can be used, but your call), new guage cluster (same yr preferrably), new fuel pump, and the engine harness/ecm for the tpi.
short list of course1978 Formula 461 in progress of being built :rock:
94 comero 3.4
Originally posted by 3.4 slow to gotranny, front springs, radiator (3.1 can be used, but your call), new guage cluster (same yr preferrably), new fuel pump, and the engine harness/ecm for the tpi.
short list of course1999 Camaro Z/28
1973 Firebird Formula
also remember that the 350 never came w/a 5spd from the factory, so if you have a built up one, nake sure the tail housing is the vss type, not the speedo cable, as it will create fewer headaches.1978 Formula 461 in progress of being built :rock:
94 comero 3.4
