underdrive pulley - FirebirdV6.com/CamaroV6.com Message Board
underdrive pulley
  • underdrive pulley
    i recently bought the crank underdrive pulley for my 92 camaro 3.1 auto and sad to say it did not make a difference. Did anybody else have the same result i had.
    Re: underdrive pulley
    Your not going to feel much on the butt-dyno. You are looking at a couple of HP at best.
      yeah if you were expecting a night and day difference you did the wrong mod. You arent really going to feel much from such a small gain like that. and probably a gain at a higher rpm
        was the pulley the only mod done? it should be part of a "package" of mods to gain the most from all of them.
        2013 Ram 1500 Big Horn
        94 comero 3.4
          I also have a hypertech chip, Accel 8mm spark plug wires and KN airfilter.
            heres the difference. ahem.....
            if you install those things one at a time over a period of say 2-3 months (just for example) then you will not notice much of a difference after each one, however.... take your car, slap all those on at once and then you should feel a difference right away.
              All those things dont really add up for much...
              even with all those (chip filter pulley, wires wont really do anything at all) added at the same time i still dont think you would notice anything...maybe 5 hp at redline
              1999 Camaro Z/28
              1973 Firebird Formula
                If you want to notice anything with these V6 cars go with a power adder, forced or nitrous. The rest is a waste of time if you're looking for hp.
                91 Firebird 3.1<br />SC12 Supercharger<br />LSD w/ 3.73s<br />NOS 80hp wet shot<br />AKA: Phoenix<br />\"If Speed Kills...Consider Me Dead.\"
                  agreed, even with full bolt ons it still sucks
                    not agreed, porting heads/intake/TB, cam swap, larger injectors, even underdrive pulley are not a waste of time, are a MUST if you're looking for the last HP.
                      and weight reduction
                      94 comero 3.4
                        FWD top end swap is even better ;)
                          improving engine breathing from anyway is always better
                            improving engine breathing from anyway is always better:cool:
                              Fully ported iron heads can't even flow as good as the FWD small port heads ;). 3500 heads flow ~218CFM out of the box at .500".
