I'm trying to bring my '89 Bird alive again. Here's my problem:
The battery works and it can turn on the lights, but it doesn't turn on the ignition, the radio, or headlight motors. I checked all my fuses and they all seem fine. So what can I do? Is this a breaker or circuit problem? If so where can I find that?
My ingition switch died recently. In my case, the main line shorted, killing the entire electrical system. Maybe yours died but killed a different circuit.
1997 Camaro, Y87 Perf. Package, iRotor Drilled & Slotted Brakes, Bilstien Shocks, Custom drive shaft, K&N Filter, & Mobil 1 synthetic. 202+K miles and still drives like new.<br />-If you can\'t stomp \'em in the straights, kill \'em in the corners...
Well, best bet would be to check continuity with a multimeter and some t-pins. You could replace them if you like but testing them is always easier than replaceing them.
And I haven't been on these boards in a very long time. I used to own a red 87 formula with a 3.4L swap.
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
