saw jay lenos twin turbo camaro in the april edition of road and track today. 425 hp out of two turbonetrics t-3s, damn not bad. only one horsepower shy of the stock SS. heres the link to the story http://www.roadandtrack.com/special_..._camaro_page_3 and the gallery http://www.roadandtrack.com/special_...-play/gallery3
lenos twin turbo v6 camaro
Last edited by chris greene; 03-15-2010, 09:02 PM.1997 3.8 5-speed Camaro<br />BMR STB, LCA\'s, SFC\'s,Panhard bar, Torque arm,1LE sway bars<br />Headers, SLP cold air, Flowmaster catback, takeoff LSD, Eibach pro springs<br />Hurst shifter, 01 Z28 guage cluster w/ white face overlays, billet grill wTags: None
Re: lenos twin turbo v6 camaro
i'd certainly hope that's to the wheels --- running twins and only getting 120 extra to the crank over stock seems too modest, but the article is saying brake horses and equivalent power of the SS. crank that psi up over 7 and that thing could be a monster.Last edited by BallerMaro13; 03-15-2010, 11:28 PM.pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
gone in body, but not in spirit
I think Leno was just proving a point to GM that it doesn't take a big V8 to put down some high horsepower. 7 PSI is modest I'm sure they could or have turned up the boost on them it doesn't say 7 PSI per turbo ot total, I'm guesing total since that would be about 140 HP 1LB of boost is most likely about 20 HP. Since 1 big single turbo by Linx put down 650 WRHP and several single turbo setups put down 450 WRHP, some at 10 PSI to 18 PSI(18 PSI was at 5200 DA). I still think our 3.8's are a better engine design for boost than the new Camaro V6 but we will see when someone puts some boost to one. Our 3.8's weigh alot less than the new Camaros and can be boosted to their WRHP with low boost so its a easy choice for me at least, esp. if I can get 400 WRHP out of my car and it weighs 2900lBS.Last edited by ssms5411; 03-18-2010, 01:17 AM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostI think Leno was just proving a point to GM that it doesn't take a big V8 to put down some high horsepower. 7 PSI is modest I'm sure they could or have turned up the boost on them it doesn't say 7 PSI per turbo ot total, I'm guesing total since that would be about 140 HP 1LB of boost is most likely about 20 HP. Since 1 big single turbo by Linx put down 650 WRHP and several single turbo setups put down 450 WRHP, some at 10 PSI to 18 PSI(18 PSI was at 5200 DA). I still think our 3.8's are a better engine design for boost than the new Camaro V6 but we will see when someone puts some boost to one. Our 3.8's weigh alot less than the new Camaros and can be boosted to their WRHP with low boost so its a easy choice for me at least, esp. if I can get 400 WRHP out of my car and it weighs 2900lBS.
BTW..I did see this car in person. I would've met the man himself if I had showed up earlier.Last edited by Mighty Thor; 03-18-2010, 04:12 AM.
Originally posted by Mighty Thor View PostTHe caddy engine is more design for NA, just like ours. But we know that the MAF can be a limiting factor for our cars and plus weak piston rings. On the caddy engine the compression ratio is too high to boost it anymore than 6psi. Ours on the other hand can take 12 intercooled boost without damaging the engine.
BTW..I did see this car in person. I would've met the man himself if I had showed up earlier.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I need to check my door sticker, but a quick google search puts our 3.8L camaro at ~ 3300 lbs. How did you shave 400-500 lbs from yours?
EDIT, nevermind, I just read throught some threads in the drag racing section. Other than the aluminum DS I don't think there is much more I would do away with as this is my son's daily driver.Last edited by jmbrooks; 03-19-2010, 11:04 PM.
Originally posted by Leonard 3.8L View PostIf there's one thing Leno knows it's cars. That is one bad Camaro ladies and gentlemen.1997 3.8 5-speed Camaro<br />BMR STB, LCA\'s, SFC\'s,Panhard bar, Torque arm,1LE sway bars<br />Headers, SLP cold air, Flowmaster catback, takeoff LSD, Eibach pro springs<br />Hurst shifter, 01 Z28 guage cluster w/ white face overlays, billet grill w
he did it on purpose he could have got alot more power out of that thing no problem but i bet he didnt change one stock part on that car and got that much power... imo it deff was made to prove a point oh and it is wheel hp
