So I fabbed up A CAI. I basically cut the tube with the MAF in it and connected an elbow and a spectre air filter an now I feel as if I lost a good deal of horsepower. So I'm going tomorrow to the chevy dealer and getting another airbox lid... Those CAI's aren't all they cracked up to be.
Cai
Re: Cai
Ok I think I found the culprit. That tube that goes tinto the intake, I separated them and plugged the ends and I got my power back, but I dont think it made any more of a difference than cutting the bottom out of the airbox.
Re: Cai
Well, the first problem I see with your CAI is that you're not drawing any cold air. Is that PVC? Also, you're still stock after the MAF, so you won't see a gain once the air hits the accordian section behind the MAF and merges with the air in the silencer. Your stock airbox was probably working much better.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: Cai
Yes that is PVC. I do notice some gain, and actually I'm not quite done with it. I was going to replace that front section But I did'nt know if I'd got more gain from leaving it like that, also I was going to run the tube to the engine between the radiator and block. I just wanted to know if I should replace that stock piece. Believe it or not the PVC works really well. It's as wide as the intakes on the CAIs and being plastic doesn't conduct heat and I can route it where I want, plus it's cheap. that whole setup only cost about 40$
Re: Cai
yea you need to get that filter to the fender area and not by your hot engine first. Then seal it from the engine bay and make the path as smooth as possible. Remove silencers and accordian paths from it and it will flow better.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 hours ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...2 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.5 days ago
