Requesting v6 5th Gen Engine Specs - FirebirdV6.com/CamaroV6.com Message Board
  • Requesting v6 5th Gen Engine Specs
    I would like to be able to sticky a v6 engine technical Specs document in this section similar to the way this is setup: http://engine.firebirdv6.com/
    Looking for all the technical data on the 5th gen v6 motors broken down by years of the 5th gen (2010-2015) such as:
    • Engine Type
    • Engine Configuration
    • Engine Displacement
    • Engine Block Material (i.e, aluminum, cast iron)
    • Bore
    • Stroke
    • Compression Ratio
    • Firing Order
    • Fuel Octane Requirement
    • Fuel System Type
    • Fuel pressure key on
    • Fuel pressure running
    • Injector size
    • Cylinder head material (i.e aluminum, cast iron)
    • Combustion chamber size
    • Intake Valve size
    • Exhaust Valve Size
    • Exhaust manifold material (i.e stainless, cast,)
    • Throttle body size
    • Thermostat temp
    • Oil requirement (i.e, 5w30, 10w30, 15w40, etc)
    • Oil pressure
    • Flywheel Hp
    • Flywheel Tq
    FirebirdGT created the one for the old 4th Gens and I can't tell you how useful this document was for me and so many others from being bone stock to hardcore mods...knowing about the key components that make the engine up like the above makes for an amazing source for key reference.
    If someone even starts helping pull the info together (let me know which year your info applies to, I'll pull it into a chart if needed.
