2010-2015 V6 Camaro Fluid Type & Capacities - FirebirdV6.com/CamaroV6.com Message Board
  • 2010-2015 V6 Camaro Fluid Type & Capacities
    2010 - 2015 V6 Camaro Fluid Capacities
    Type Fluid 2010 Camaro 2011 Camaro 2012 Camaro 2013 Camaro 2014 Camaro 2015 Camaro
    Automatic Transmission Fluid Dextron-VI 11.4 Quarts (dry) 11.4 Quarts (dry) 11.4 Quarts (dry) 11.4 Quarts (dry) 11.4 Quarts (dry) 11.4 Quarts (dry)
    AY6 Aisin Transmission Fluid 75W-90 Gear Oil 1.9 Quarts 1.9 Quarts 1.9 Quarts 1.9 Quarts 1.9 Quarts 1.9 Quarts
    Brake / Clutch Fluid DOT 3 Brake Fluid UNK UNK UNK UNK UNK UNK
    Power Steering Fluid GM Part # 89020661 UNK UNK UNK UNK UNK UNK
    Engine Oil 5W30 6 Quarts 6 Quarts 6 Quarts 6 Quarts 6 Quarts 6 Quarts
    Coolant Automatic Transmission Cars 50/50 Dex-cool and water 10.8 Quarts 10.8 Quarts 10.8 Quarts 10.8 Quarts 10.8 Quarts 10.5 Quarts
    Coolant Manual Transmission Fluid Cars 50/50 Dex-cool and water 11.2 Quarts 11.2 Quarts 11.2 Quarts 11.2 Quarts 11.2 Quarts 10.9 Quarts
    Rear Differential 75W-90 1 Quart 1 Quart 1 Quart 1 Quart 1 Quart 1 Quart
    **Rear differential limited slip additive quantities are 2.5 ounces for 2011 and older models and 3.3 ounces for 2012 and newer 5th gen models.
    All capacities above should be used as an estimate and you should always verify fluid capacities in your Camaro when replacing fluids to avoid unwanted damage. Links contained in the Fluid column above go to our Amsoil sponsor site for the corresponding lubricant.
