5th gen V6 engine bay
Re: 5th gen V6 engine bay
Originally posted by Bonemaro View PostWhat kinda power do those 3.6'ers put out?
Displacement: 3564cc
Assembly Site: St. Catharines, Ontario
Configuration: Dual Overhead Camshaft (4 valves per cylinder).
Horsepower/Applications:
255 @ 6500 rpm (SRX)
256 @ 6300 rpm (G8)
263 @ 6400 rpm (CTS)
Torque:
248 lb-ft @ 2100 rpm (G8)
253 lb-ft @ 3100 rpm (CTS)
254 lb-ft @ 2800 rpm (SRX)
Features: Continuously variable cam
cool so i can buy 10 years after production
Horsepower is how fast you hit the Minivan... Torque is how far you take the Minivan with you... :wavey:
Originally posted by Firehawk N WvMine were rusted also and the I had to cut my nuts off .
nasty intake silencers. that'd be the first thing to go if i bought a new v6.
Follow me!
Or this
Originally posted by IICODECll View PostOn the Cadillac website it lists the "Direct Injection 3.6L V6 VVT" as having 302 HP. In any case, how hard do you think it will be to fit one of these into say a late-4th gen? =]
since I wont register on yet another site: the engien in the 5th gen looks like the 256hp 3.6
why: look at the oil filler cap, p/s cap, and whatever that other cap is, compare it to the pic of the g8 v6.
someone on tgo is working on/has a kit to transplant a 3.6 into the 3rd gens
:naughty: :stp:
edit: http://www.thirdgen.org/techboard/v6...-swap-kit.html1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
Originally posted by t-topV6 View Posteven better... that would be like the 4th gen v8's...:drool:
GM underrated the power output for the ls1 in the z28 and ss so the numbers wouldnt be comparable to the vette
the ss engine is most likely, if not the same engine that went into the corvette
