I did some searching and could not find a definitive answer. For all of you that have eliminated your balance shaft what did you do to plug the rear oiling hole? I am removing the shaft and am unsure as to what i need to do to plug it. I really need to be pionted in the right direction.
For all that have eliminated the balance shaft...
Re: For all that have eliminated the balance shaft...
I just completed this mod when rebuiliding my 3.8.
There is an oil journal that feeds the rear bearing for the balance shaft from the back of the motor. The hole is accessible only after you remove the rear cover in the back of the motor that holds the rear main seal. You need to thread the hole and insert a pipe plug in it. I had the machine shop do it but I believe it was a 1/4 or 3/8 plug. The motor has to come out to do it.
If you are not pulling the motor you have to leave the shaft in place and d just remove the drive gear.
Scott
If your putting on a double roller most just remove the drive gear.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Thanks for the replys, the block is already at the machine shop getting worked on so figured i would go ahead and have this done so i can run a double roller.Daily: '02 Black Yukon Denali
Toy: '06 Torrid Red GTO
Gone: '07 Charcoal Yamaha R6
Gone: Ex-wife, lol
There's a cam bearing for a certain chevy engine, I believe, that can be pressed in... I think the part # is on this site somewhere, or at least the engine that you'd have to look up... It'd be a much cleaner and I'd think safer fix... but... I just tapped and plugged mineRebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
No I did not take pics of that part of the engine. But when you remove the rear bearing for the balance shaft you will see the oil journal hole. If I recall correctly it went from the bearing about 2 inches diagonally down toward the back of the block and exited near the rear cam bearing hole. Its all covered up by the rear plate that holds the rear main seal.
Scott
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.4 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
