Ok I have been debating on posting this or not but... Here goes.
I just purchased a 1997 3.8 Auto that was reported to have a bad head gasket. Car needs some additional work but I figured Hey for 900.00 out the door I cannot complain. I looked at the car on the lot and could not find ANY sif a blown head gasket. I did find signs of an overheat in the past, a water leak and a power steering leak. I started the car on the lot and it ran OK, a little rough butr nothing I could not handle. Purchased the car and drove it the 35 miles home, NO issues on the road other than loosing water and power steering fluid.
Got the car home and up on the ramps it went. I got to looking around it and found that the water leak was from the coolant bypass tube, $4.00 and about an hour work and that is now fixed. No more loosing water that I can tell. I tried to run a compression test on it the other day and I ma having trouble getting the hose from the guage to seal properly in the number 3 cylinder (any tricks?) I am going to try again this weekend.
OK so after that long back story here is the question. As I stated I am not seeing ANY signs of a head gasket leak. No nasty oil or water no smoke nothing. Car has a random misfire and an egr code but nothing else. What are the chances that I just got REALLY lucky and the head gaskets are fine? Also if I do have to change the head gaskets can I get away with just a gasket set or am I going to have to mill the heads?
I guess that is it for now. Thanks to all in advance for any advice or assistance on this one.
