The shop I work for pulled a 6.0 out of an 02' chevy 2500 and the cust wants to replace due to a collapsed lifter. This thing looks to be in really good shape; big aluminum heads screaming to be ported out, and I can still see the honing in the cylinder walls. I would like to put it in the camaro and I can have it for the core charge, but I have a few concerns. One being the motor mounts and two being the pcm and harness. Does anyone have a clue as to what pcm I might be able to run, LS1 maybe? Then adapt the wiring to the sensors? I have HPTuners with some credits.
6.0 swap?
Re: 6.0 swap?
do a bit of searching on LS1tech...they swap anything and everything over there...you could probably go to a machine shop and have them make you custom mounts...and why not just get a hold of the trucks pcm and wiring harness, and do it like that?
Re: 6.0 swap?
Originally posted by LETZRIDE View Postdo a bit of searching on LS1tech...they swap anything and everything over there...you could probably go to a machine shop and have them make you custom mounts...and why not just get a hold of the trucks pcm and wiring harness, and do it like that?
Re: 6.0 swap?
Originally posted by Fondle View Postthey are putting another motor in the truck, so they probably want to keep it, but you will need a pcm from a truck like it most likely
