I am getting ready to swap an 05 Buick FWD L36 into my 99 Firebird and I need to know if I can re-use the crank/balancer bolt or if I should go ahead and order a new one? I've been working on LS1's for years but this is my first experience with the L36. I know the LS1 crank bolts are TTY and can't be re-used.
Is the L36 crank/balancer bolt reusable?
Re: Is the L36 crank/balancer bolt reusable?
Their TTY, not to expensive, better to be safe than sorry later on.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I reused mine when i did my cam install over 10,000 miles ago and never had any problems. I was also talking to my machinest about it, a lot of bolts that are labels TTY are not always so. I would do this. If you are at all concerned about it buy a new one, they are cheap, just like SSMS said. Just my .02Daily: '02 Black Yukon Denali
Toy: '06 Torrid Red GTO
Gone: Powerdyned '02 Pewter Camaro
Gone: '07 Charcoal Yamaha R6
Gone: Ex-wife, lol
Yes , the washer will be fine. I know I picked up 2 cam bolts and 2 crank bolts , just in case in the future if needed, plus I used my Dads GM dicount before he retired from GM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
j/w why you are swapping out the balancers? The FWD one should work from what i'm seeingCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Originally posted by v6mOtOrhEAdftOp View Postj/w why you are swapping out the balancers? The FWD one should work from what i'm seeing
I have one sitting here (not enough time to work on it though) and they both look and measure up very cose. The designs are a little different, but I assume they spin the same wayCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
if it is a gtp balancer then it is for sure different as they run a dual belt setup
ya the heads are different on the gtp motor also. Mine's a gt1 motor and it seems the sameCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
