Car is acting funny beyond what I know..... - FirebirdV6.com/CamaroV6.com Message Board
  • Car is acting funny beyond what I know.....
    My problems started yesterday when I got into my car and started it up. It took about 4 seconds of clicks for the car to actually start and idle. Didn't really think anything of it. Tonight I headed out and the car did the same thing. After 4 seconds I let the key go and then tried again. After 3 seconds the car started up. I made it to my destination but after that is where my problems started.
    I went to start the car up and it was in idle mode but after 1 second it conked. I got it started back up but this time it had the "reduced engine power" light on. While the car was in neutral I pressed the gas and the only I got was the car shaking slightly and NOTHING.
    I had my buddy with me so we popped the hood to see if anything was loose and nothing. I figure since I was less that 3 miles from home have him follow me and try to make it back. I put it into drive and was able to get to adequate speed to make it home, mind you without the gas pedal giving me sufficient power.
    In my years of driving I have never heard nor seen anything like this at all. I recently installed a whisper lid so I figured this may have something to do with it but I still have the original piece that connects the sensor into the plug from the old intake installed and that did nothing.
    I have to figure that this is being caused from something in the intake but I am stumped. Originally I thought it may be bad gas but that wouldn't lead to problems like this.
    Please give me some advice because this just absolutely baffles me on what this problem could actually be.
    Re: Car is acting funny beyond what I know.....
    I would look at the fuel system. Most likely fuel pump is on its way out. You need to check the pressure. Are you hearing it prime when turning the key?
      make sure all connectors are plugged in and scan for codes, could be your maf.
        thought of it and it may even be a small vacuum leak somewhere. But I would first scan for any codes and let us know what you come up with.
          If you installed a K&N filter on with that whisper airlid I'd clean the maf.
          TEAM C6V6
            I went out and bought dry gas and it seems to be running fine. I guess I must have gotten bad gas.
              yea I initially thought it may have been gas...
                i had a problem with mine but the reduced engine power light didnt turn on and it kind of back fired and shook alot like it was gonna turn off it did that once i took to get it checked and found out it was because i switched to a different gas company
                  same here, i was thinking either a bad fuel filter, or a clogged fuel filter sock
