How much does it normally run to have this done and install new valve locks, valve seals, retainers and sping if i remove the heads myself and bring them to a shop?
Porting and Polishing Heads
Re: Porting and Polishing Heads
depends what you have done...can go anywhere from 200$ up for a P&P...stock valve locks should be fine if your not going with an aggressive spring...are you going bigger valves as well? if you can take the head off yourself, you can install all that stuff onto the head...its much easier to do then taking the head off itself...
well i was going to get the valve locks from zzp and yea i can remove the heads but i don't want to port and polish them. i thought they remove the valves and all when porting and polishing the heads. I was planning on getting them maybe rebuilt.
You can get a spring compressor from harbor freight for $10 and take out the locks, retainers, springs and valves. I had mine blasted clean, 3 angle valve job and milled .010 for $250. This was after I P/P them. Now I have new stock valves, Comp 130LB springs, ZZP modded retainers and Comp locks with Viton seals.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Choppers View Postwell i was going to get the valve locks from zzp and yea i can remove the heads but i don't want to port and polish them. i thought they remove the valves and all when porting and polishing the heads. I was planning on getting them maybe rebuilt.
to take it apart you use the compressor and compress the spring which exposes the locks at the tip of the valve...pull em off and release the compressor...everything slides right off lol...Last edited by LETZRIDE; 01-05-2010, 12:37 AM.
Originally posted by Choppers View PostSo to have them ported and polished you guys think will run me somewhere between 200-250?
Well let me ask you guys. My grandmas boyfriend use to port and polish heads for anything with a flow bench but now he doesn't have it. Does it really need to be flow benched and also can you really mess anything up porting and polishing these heads(if he doesn't have that)?
I'd say that if he used to do it successfully then he would have the ability to do it to yours. I'm not a P&P expert, but there are principles that are going to apply to all heads, regardless of manufacturer. Granted, he's not going to be able to flow bench test them for absolute optimal performance, but if he knows what he's doing you should get a nice improvement over stock.
I think you also need to get the upper and lower intakes port matched so there is a clean, clear path for the air all the way through. Good heads won't help if the upstream pathways in the intakes still suck.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
I might just wait until I really want to do a build later on. I am going to go ahead and cam it and change the valve seals, retainers, springs and locks. I don't really need to remove the heads I was just thinking about it. Or I might just wait and buy some aluminum heads later down the road.
you can mess up the heads and lose performance doing a P&P if not done correctly. If this person you mentioned has done it professionally in the past then he should be able to do a basic job on it for you to free up some power. But yea have the intakes matched to the heads.
he use do build racing go-kart motors and race them nationally. He also sold his stuff and traveled the US. But I just don't know if I want to take the risk of him messing something up being he can't flow bench it.
I'm leery of counting P&Ping go kart engines as experience in P&Ping car engines. If you do end up doing this, I'd suggest finding someone with automotive experience or buying a set of P&P'd heads.
If you're going to have everything torn apart for doing the cam and such, getting the heads off isn't that much more work. Now would be the time to do it.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
yea thats my biggest concern but I have seen his work on high end racing atvs and the racing go karts and its outstanding. But I think an automobile head might be totally different. He told me he could do it but it would be better for him to have the flow bench so I think I will pass since he said theres only so much he can do without a flow bench to flow test his work.
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.4 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
