So when I get my tax return, I'm going with the GT1 Cam 105# springs LS1 retainers, but I was wondering if I need to change the timing chain dampner and if I need to replace push rods or can I just use the stock ones.
Couple of Cam Questions
Re: Couple of Cam Questions
Originally posted by SixShooter'00Camaro View PostSo when I get my tax return, I'm going with the GT1 Cam 105# springs LS1 retainers, but I was wondering if I need to change the timing chain dampner and if I need to replace push rods or can I just use the stock ones.Daily: '02 Black Yukon Denali
Toy: '06 Torrid Red GTO
Gone: Powerdyned '02 Pewter Camaro
Gone: '07 Charcoal Yamaha R6
Gone: Ex-wife, lol
Isnt there a clearance issue with the double roller timing chain? I cant exactly where I was reading it. I think with either the oil pan, or the cover. This one one reason double rollers fail, is because they rub and it causes them to weaken.
Also isn't there only one brand left that makes a double roller for our 3.8s and didnt many people have problems with them?
Originally posted by whitdog54 View PostIsnt there a clearance issue with the double roller timing chain? I cant exactly where I was reading it. I think with either the oil pan, or the cover. This one one reason double rollers fail, is because they rub and it causes them to weaken.
Originally posted by Choppers View Postits the cover. Me personally would run just a single rollmaster. You should be just fine with that. Why are you downgrading to the GT1 from the GT2?
Originally posted by LETZRIDE View Postyou have to mill the oil cover...and you have to mill the sprocket I believe...there is a write up covering how/what to do on FTV6 on how to do it so that the chain doesnt rub and it doesnt fail....
Both Rollmaster and JP Performance market doublerow chains for 3800s.
A doublerow timing chain/gear set can only be used if the factory balance shaft is disabled or removed. If you remove it, the balance shaft oil feed hole at the rear of the block must be plugged or you have a big internal oil leak.
My belief is that a single row chain is good for all but the most aggressive---high rpm and high valve spring pressure---racing applications.
Sprocket doesn't have to be touched, but the oil pump drive cover needs to be shaved,or you need to use two stock paper gaskets (not the best choice).
I have shaved several oil pump drive covers down on my surface grinder and might even have an extra if you need it...
I wish I had taken a pic of my friends cover after he used it without shaving it down, you can clearly see the gouges from the chain rubbing.
With high spring rates, I would definitely recommend the double roller.
You need to contact your cam supplier and see if your stock push rods will even work or not since the rockers are pedistal mount and are non-adjustable. I know last time I installed an Abbott cam,the stock rods were NOT the correct length since the base circle needs to decrease to create more lift/duration.
Those look exlactly like the ZZP machined ones I got for mine, but it sucked paying $35 for one. LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostThose look exlactly like the ZZP machined ones I got for mine, but it sucked paying $35 for one. LOL
Originally posted by Forced_Firebird View PostSprocket doesn't have to be touched, but the oil pump drive cover needs to be shaved,or you need to use two stock paper gaskets (not the best choice).
2ndly, I believe you should only use 1 paper gm gasket...eventually gaskets compress so don't rely on the gasket for the spacing...it should be milled properly...
and JP and rollmaster are the same company now...
What should you use to plug the balance shaft oil feed hole?
