Which one is better zzp's or abbotts? Also on zzp's which options would you pick?
Cam Install kit
Re: Cam Install kit
There's alot of variables... it all depends on what cam you're installing... what your supporting mods are... what your eventual goals are for the car...
Give a little more info...Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
Re: Cam Install kit
I am talking about the gaskets and all. I am going with abbott's I think since I will be spraying it. I have swapped between the gt2 of zzps and abbotts n/a a hundred times. But those are the cams I will be pciking from.
I am upgrading to:
Comp Cam 105 spring
Comp Cam valve locks
ZZP Modded Retainers
Viton Valve Seals
Comp Cams OE Lifters
Rollermaster Single Roller Timing Set
Then the cam. Thats all I am doing.
Re: Cam Install kit
well make sure if you go zzp that it is for the fbody car and not a wbody as the 3.8s in the wbody cars use different gasket sets
Re: Cam Install kit
Originally posted by FreakV6 View Postdifferent crank bolts too, found that out the hard way (as in when i was reassembling everything)
