I've just got a simple question. Do you need to take the heads off of the 3800 SII to get to the lifters, or do you just have to take the upper and lower intake manifold off. I've got a noise that I believe is a stuck lifter...
How to get to Lifters
Re: How to get to Lifters
just the upper and lower intakes, no need to remove heads
you do however need to pull the valve covers off and remove the rocker arms
Originally posted by 99BlackW68 View PostI've just got a simple question. Do you need to take the heads off of the 3800 SII to get to the lifters, or do you just have to take the upper and lower intake manifold off. I've got a noise that I believe is a stuck lifter...
Originally posted by timthescarred View PostIn the old SBC's you could remove lifters by just taking off the valve covers, there was a long tool that slide down the pushrod hole and pulled 'em straight up and out if i remember right. Is this still the case or no?
While we're on the topic.. I haven't been into my intake manifolds either and I believe I have a noisy lifter too. Any advice on any specific lifters to buy? And maybe where? I just looked on autozone and they have some melling brand that's like 10 bucks a pop.
TEAM C6V6
Originally posted by Blizzard242 View PostWhile we're on the topic.. I haven't been into my intake manifolds either and I believe I have a noisy lifter too. Any advice on any specific lifters to buy? And maybe where? I just looked on autozone and they have some melling brand that's like 10 bucks a pop.
i havent heard anything bad about them recently though, but they are a reputable company, not some cheapo lifters you could buy at harbor freight
OEMS are fine...infact it is reccommended to go oem rather then the OE R series...
Comp Cams OE lifters are what you will want. Stay away from Comp Cams OE-R unless you like noise. I have the OE-Rs and hate them because they are so noisy
Originally posted by 97rs4life View PostComp Cams OE lifters are what you will want. Stay away from Comp Cams OE-R unless you like noise. I have the OE-Rs and hate them because they are so noisy08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Another quick question.. sorry if I'm thread jacking.
I'm replacing all the pushrods as well.. I installed the pushrods that came with my yella terra 1.7's and I honestly don't know much about em. Please correct me if I'm wrong but I imagine they're stock length and specs. Either way, I need a bit of guidance with a damn good pushrod. I've got heavier valve springs so I need everything strong. If you're wondering they're just 105's but heavier none the less.
TEAM C6V6
If yella terras are light weight don't use them , I bent 8 out of 12 light weight pushrods when I used intense's pushrods. The Comp 5/16" pushods are doing fine right now , but I will go alittle heavier with Comp .105 's when I get the Comp 1.7 Pro Mags rockers on and switch from Comp 105lb springs to Comp 130lb springs.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
yeah push rods are something that you DON'T want have "lightweight" you want the strongest push rods you can find because if you hit your rev-limiter or accidentally downshift when you want to up shift you WILL bend a light push rod.
anyway, thanks for the info guys :D
1999 Firebird Y87/W68
Do the lifters just pull right out? I just got my comp cams oe lifters in the mail tuesday1997 Chevrolet Camaro
L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
