has any one tried out either one of the pistons yet? and maybe a dumb question but you think they woulde be a upgrade at all cause it doesnt say they are lighter or stronger really. thx http://www.summitracing.com/parts/STL-WH522CP/
different pistons
Re: different pistons
http://www.summitracing.com/parts/UEM-1745HC-STD/ this is the other one my bad
I would say that neither of those would be an upgrade. If you're looking for added strength, forged pistons and rods would be the way to go. But unless you're looking to add a turbo, supercharger, or a good bit of nitrous, I would say use the money for something else.2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
you could upgrade by using the pistons to up the compression for a NA car...I dunno about those ones in the link though...
Originally posted by Fondle View Postunless you have major plans for the car i wouldnt bother changing the pistons, the stock pistons in our car can hold some good power
Originally posted by LETZRIDE View Postyou dont need to necessarily change out pistons to hold more power...you can change them out so that you can run more compression. To run anything higher then 9:9:1, or 10:1 you need to swap the pistons out to achieve it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
ok well i wasnt sure if we had pistons that were made of steel or sumthing thinking they would be lighter or sumthing idk switching to these alum. ones thanks for the info i know about the diamond forged pistons and was still going for these when i swap them but thought id see what you guys thought of the cheapys
the second link says 96.500mm bore are engines are 96.520mm stock so im nnot sure if it will seal? then again its 2 tenths of a millameter. Looks like is has a higher compression it has 1.090" compression distance and a .050" recess the other one is 1.855" comp dis and a .135" recess. I dont know how to figure what that makes the compression thoLast edited by 01PewterDropTop; 02-04-2010, 12:14 AM.
