I have a 97 stocker and a 01 modded i want to use the 97s fuel rails on my 01 with gtp injectors but i want the then put the 01 injectors and rails on my 97 will this work?
01 injectors and rails on a 97?
Re: 01 injectors and rails on a 97?
I think it will work. I could be wrong but I think the 97 rail is short like the gtp injectors and then the 01 injectors are tall along with the rail, so i think it should work out perfectly.
Yea caspernicus is right about the clips, but its no big deal i did it on my 00 when i out gtp's in as well. they also make adapter clips too so you don't have to cut the old ones off and solder the new ones on. i soldered mine in it wasn't that hard to get to them. good luck with it!Last edited by mtscorvette; 02-03-2010, 09:58 PM.
I'm not sure what clips the 97 has but the 01 has delphi mini connectors i think and the gtp's are ev6 connectors. you would just need something like this or adapters
http://cgi.ebay.com/ebaymotors/Bosch...Q5fAccessories
Originally posted by 01PewterDropTop View PostHumm. so the GTPs arent direct plug in on the 01 harness? are the direct plug in on a 97? i dont mean plug and play just the connectors
with a different style injector starting in 2000.
no it is part of the harness. You would have to cut the connectors off and splice them into each harness.
The gtp injectors will work with the 97 rail and 97 harness. Not the 01 rail and harness unless you swap connectors. So no not a direct swap between the two
