does any one have a part number for them? I called arp and they dont have a listing for a 99 camaro 3.8L connecting rod bolt. the ones at ZZP say 'Does not work in the L32 engine." im trying to get all the parts i need to start my rebuild i spun a rod bearing:( will be using new rods from ZZP.
thanks for helping.
1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
so guess im a bit confused. I want to use L32 Powdered metal connecting rods from zzp but the ARP bolts they sell wont work with the L32 engines which engine do they work in? also since mine is a L36 will they work?
I want to use the new stronger rods since i run nitrous and maybe one day supercharger. the L32 rods say they come with new bolts but wanted strongers bolts for the power adders will the bolts they come with be strong enough?
I went with the L32 rods back in 03' with Diamond pistons, clev. 77 bearings but can't remember what rod bolts were used. I think stock was used the stock ones have held up pretty good so far so I can't complain. Ran over 300 WRHP with the powerdyne, 330 TQ and 125 -150 shots of nitrous and the engine still runs like a champ.
