vacuum line diagram - FirebirdV6.com/CamaroV6.com Message Board
vacuum line diagram
  • vacuum line diagram
    Is there any diagram or list available that I can get ahold of that will have Every single vacuum line and its location in our car please?
    I want to replace all my vacuum lines and possibly my MAP sensor in an attempt to diagnose my ve tunning issue.
    Re: vacuum line diagram
    You can cap both sides of the map sensor. One goes to the
    fpr and the other goes to a cluster beside the pcm. By unplugging
    the fpr you'll have wot fuel pressure all the time, but it's not a big
    deal.
    That would narrow it down to the brake booster hose and map
    sensor.
    *edit*
    and whatever the hell that plastic line is on the passenger side of
    the intake that you early guys have.....lol
      deal.
      sensor.
      *edit*
      no idea what that plastic thing is, and we got 3 lines that come over to the pcm area as well...
      How can I cap the MAP? and would unplugging the FPR be a bad thing?
        You'll just have wot fuel pressure all the time. If the fpr is bad then
        fuel will come out of it.
        Once you cap the 'nipples' on the map those lines by the pcm will be
        eliminated from the equation.
        They sell vacuum caps at autoparts stores. You just need to figure out
        what size you need.
          so if fuel is going in those vacuum lines because the FPR might be "bad"...where the hell would that fuel go?
            There's only one place for it to go...... the intake. The line from
            the fpr to the map doesn't go to anything else.
