turbo engine build - FirebirdV6.com/CamaroV6.com Message Board
turbo engine build
  • turbo engine build
    alright i am wanting to build a turbo engine for my 97 camaro rs. i just bought the block and i am trying to decide on pistons, rods, cam etc. im trying to get the best parts i can and take my time. i would rather do it right the first time around then put it in and pop the engine. im also debating on if i should bore it over and is so how much?
    Re: turbo engine build
    I've heard good things about Wiseco pistons and L32 rods. Dont bore it out if you are going to boost it.
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
      i thought that boring it out would make it better for boost?
        also what about ross forged pistons and manley rods?
          what are your goals for the engine? A stock bottom end can take quite the punishment of a turbo and pistons and rods may not be needed if your power goals don't need them. Mainly the tuning is what is key for turbo engines and longevity
          http://www.bowtiev6.com/
            well im wanting to possibly reach 500hp to 650hp and as far as parts all i really have is the block so im wanting to build it from ground up. i want it to be a street car and just cruise around on weekends and stuff but have the power to take it to the drags or drift track when i want too.
              and what is your budget? Do you want to stay 3.8l or go with a forged 4.2L stroker kit as well?
                well im going to take my time and buy it piece by piece so price doesnt really matter that much. i would rather get the right parts then taking a shortcut and paying for it later. i did consider the 4.2 stroker kit but from what ive heard they are not as reliable granted ive never talked to anybody with it either. just mainly mechanics
                  k, so hp numbers the only thing important to you or are their track time goals too? Also what trans and gears do you have? Any current mods?
                    i dont have any huge mods but i do have a cold air intake that i made out of 3" spectra flex tube and a huge spectra air filter and relocated the iat by the air filter. i also have kyb agx shocks in the rear. i dont really have track time goals but i would like the setup to be pretty well rounded between street, drift, and drag. all my gears are oem but was considering buying a z28 or ss rear end so i get the lsd and rear disks
                      have the block cleaned up and checked out. Don't bore it unless the machine shop finds something during checking it out.
                      The l32 rods with a set of nice pistons will be just fine, no need for custom rods.
                        who would you suggest as far as pistons? im basically going to build this motor completely then try to take a 3 day weekend and swap it. and the block is guaranteed by the warehouse i buy them from. they have a ton and it was only $100 for the block
                          im trying to make a list of everything on an engine so i can just check it off as i get it.
                            ya but they are not going to gurantee the work you did to it if you find out something is wrong with the block...they'll give you another block and you have to start at square 1 with the work again...
                            the cartuning kit is making some nice hp numbers...with that turbo kit only we have a local guy putting down 400rwhp with no other mods done (except fuel pump)
                            I would say that kit, along with a nice turbo cam, a nice set of heads, and a custom intake manifold...you'll be at your goal no problem.
                              so you think i can hit in between 500 and 600 with that kit, cam, heads, and an intake?
