Hey everyone, I've replaced all my gaskets from the heads up 3 times since my car has been down, and I'm still leaking oil/water upon start up at the front of the motor. I asked a local mechanic and he said it was most likely the 2 rubber gaskets between the block and the lim. He said the oil will push past that gasket 8 times out of 10, and just to use a 3/8 bead of rtv on it. Has anyone else had this problem?
intake gaskets
Re: intake gaskets
Your suppose to use the RTV and then put down the rubber gaskets, I use alot of RTV then put the lower on and tighten down and let set for 24 hours to dry. Then do the upper and the rest.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: intake gaskets
^ I know on my old 2000 Grand am when I did the lim I didn't use rubber gaskets at the ends. But I made sure there was a good amount of the good GM sealant , comes in a tube and is gray in color. That stuff is like cement.LOL But if your using the new alm. LIM gasket kit , might as well use the rubber seals just use sealant around them and esp. in the corners. I'll be doing mine here soon again when I put on my built heads and P/P intakes and swap my OER lifters out and put in Comp OE lifters, along with some other, goodies.:naughty:08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: intake gaskets
The gasket kit came with an illustration of those 2 rubber gaskets and it said not to use the permatex under the gasket just on the corners where they meet the gaskets that go on the heads. I did it like this the first 2 times, then I gooped the hell out of it under the gasket and on the corners the 3rd time, and still leaking.1997 Chevrolet Camaro
Re: intake gaskets
I'm completely stumped!!! Pulled my intakes off today and there was no sign of blow by on the rubber end gaskets. Plus I broke off a corner of my upper intake. Don't ask me how. I just have bad luck I guess. So should I mabey get a compression tester and see if I have a problem with my bottom end? When I started it up last time oil was running down onto my harmonic ballancer and dripping off it. But I don't know where its coming from.1997 Chevrolet Camaro
Re: intake gaskets
What would you guys do???1997 Chevrolet Camaro
Re: intake gaskets
I would check the heads to make sure there not leaking, or use dye in the oil to find out where the leak is, I've used dye for oil, A/C, tranny , rear diff and power steering leaks. Best way to find them so you know exactly where the leaks are.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: intake gaskets
did any body find out what caused this problem????
i had this problem also i had replaced the engine and had to replaced intake i also replaced all the gaskets except head gaskets
and it leaked oil at the harmonic when i ran the car after it heated fully
i replaced the timing seal twice and put on a seal kit also I pulled and checked the oil pump but still leaked when fully warm
also oil pressure dropped when it leaked and dropped when you let off the gas at road speeds i believe the cats were plugged and creating back pressure I have new cats just not interested in repairing I also had water in the oil which i have repaired this problem but have not put on new cats yet The person before me ran the engine a long time with check engine light on which could plug cats
anyways just wondered if any body else had this problem??? thanks
Re: intake gaskets
I havnt figured it out yet, I'm gonna replace the gaskets at the front of the motor and if that dosnt fix it, I'm gonna give up on this motor. I've found a couple l26s for pretty cheap.1997 Chevrolet Camaro
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.4 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
