Si Valves - FirebirdV6.com/CamaroV6.com Message Board
Si Valves
  • #31
    Re: Si Valves
    Originally posted by Turbo V6 Camaro View Post
    i'd be more worried about hte 105 springs lots of those have failed too,,,,, I havn't seen any cases for a while maybe Comp finally found the issue
    gee...my day keeps getting better and better with this news...
    • #32
      Re: Si Valves
      They fixed the 105's awhile back about 2-3 years ago , I bought a set of used 105's from someone and emailed Comp and gave them the batch # and they sent me a envolope to send the 105's back in and sent me a brand new batch of 105's , I guess they figured which batches were bad. I haven't had any problems with the batch they sent me, with 125-150 shots of nitrous. There were also bad batches of 130lb springs which they recalled.
      • #33
        Re: Si Valves
        abbott even told me that would be fine, but seeing all the post i had him order the manlyes with the 1.84 and 1.55 size
        should be noted at least 2 sets of abbot stage 3 head have failed due to the valve ejecting its head, and one was on an NA setup
        was he able to get a more reasonable price then 360 dollars for the full set? do they make stock sizes? and what did he do about the stem size difference?
        • #34
          Re: Si Valves
          he had them made as far as i know, they are 1.55 and 1.84, i can't find the biuld sheet for the price at the moment :tdown:
          N2OEQIP
          at the time i was on the stock rockers that came with my car.. .
          i now run the Compcams rockers 1.72
          www.turbov6camaro.com
          1997 3800 Series II Camaro
