Where else could coolant leak from if it is NOT from the radiator, all hoses, or water pump?
I can kinda see a little coolant puddle up top by the intake.. It only leaks to the ground when the car is started up and running. I can probablly loose close to a quarter of a gallon per day
so I have a coolant leak, and its not leaking from the radiator, hoses, water pump, water outlet or heater core; the leak seems to be coming from my intake manifold, but not for sure. Now I am aware that there is a lower intake manifold gasket and an upper plenum gasket. Can coolant leak from either gasket, or just to the lower? Is the upper just strictly to prevent a vacuum leak or does coolant flow through there also?
Well if it's dripping when it runs that should be pretty helpful in finding the location it's coming from. When the car is off and cooled down, clean up as much coolant as you can then start it up and look for where it's coming from. Pretty straight forward..
And yes, like they said, coolant does run through the throttle body.
