I'm doing a 3.8 V6 to LQ4 swap, and I dont want to buy entirely new accessories as its going to rake nearly $1,800 in costs. I want to know if the A/C Compressor and Power Steering pump off my V6 will bolt to the LQ4 / LSX style motor?...
Interchangeable Accessories???
Re: Interchangeable Accessories???
Don't thinnk so , Wouldn't the LQ4 have its own access. like doing a LS1 swap with the whole block and tranny. Only reason the power steering off the LS1's can be used on 3.9's is becuse they have the same front suspension, but the A/C's are differnet , alt. etc.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostDon't thinnk so , Wouldn't the LQ4 have its own access. like doing a LS1 swap with the whole block and tranny. Only reason the power steering off the LS1's can be used on 3.9's is becuse they have the same front suspension, but the A/C's are differnet , alt. etc.
You said the P/S pump can be re-used though?1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
Nope, you can't use any accy's off the truck engine. You need F-body accy's. Real men don't care about A/C and PS.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Originally posted by Bird_Of_Prey View PostNope, you can't use any accy's off the truck engine. You need F-body accy's. Real men don't care about A/C and PS.
Originally posted by SilverRS96 View Postac? whats that?1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
