After a lil Friday night fun at WOT, I stopped at a light and see the check guages light come on. My oil PSI needle was laying at the bottom of the guage and I turned the radio down to hear the bottom end going "chirp chirp chirp" It was idling fine just chirping, so i let it idle to the nearest parking lot and had it towed home. Its been in my driveway since.
A little background info, I just changed the upper and lower intake gaskets 500miles before this happened. I changed them because I had oil in my radiator. The sludge I pulled out of the radiator I noticed had metallic flakes in it. I knew I probably shouldnt be romping on the car, but you know how it goes. My oil psi guage has always kinda bounced around. I figured it was a bad sensor. My oil psi was generally around the 1/4 - 1/2 mark depending on how many RPMs I was at. But sometimes at idle it'd bounce around all erratic.
The car has 170k on it. This cant be good..
