if i swap my 3.4 wich bolts to the 4l60e tranny as all of you know, with a small block 350 4 bolt, and put a carb on it do i need a wiring harness and computer or not. will this idea become a big money pit?
350 sbc swap
Re: 350 sbc swap
You would keep the computer and delete the engine sensors running a distributor, ignition coil and ignition box. IMO unless your confident you can do most of the work yourself I would stick to a more common swap to avoid some of the unforeseen costs. k-member and engine mounts would be one of the first issues.
Re: 350 sbc swap
Originally posted by nelsjosh View Postif i swap my 3.4 wich bolts to the 4l60e tranny as all of you know, with a small block 350 4 bolt, and put a carb on it do i need a wiring harness and computer or not. will this idea become a big money pit?
The 4L60E behind the 3.4 will not work with the 350.sigpic
Re: 350 sbc swap
Originally posted by techsan23 View PostYou would keep the computer and delete the engine sensors running a distributor, ignition coil and ignition box. IMO unless your confident you can do most of the work yourself I would stick to a more common swap to avoid some of the unforeseen costs. k-member and engine mounts would be one of the first issues.
edit* for everything you need to do the swap
Re: 350 sbc swap
You could go with a Speartech wiring harness if worried about doing the wiring.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
