Advance tech is dead...mine as well make a thread for this anyways so you guy can watch my slow progress hahaha....
So this is what I got done today.
Not the prettiest, but if it works that's all that matters...can work on aestetics later.
So, so far I got the bottom mount base plate done (one that I will have bolt up to the holden manifold), and 4 of 6 throttle bodies...the other 2 throttles should be done soon. Then I can go on to making the two side mounting plates (plates that connect and hold the tb's in place)
Then I pretty much need to wait until either A) I get a job, or B) I sell this second car so I can get some funds to buy my mandrel bent piping....after that it's a matter of welding it all together. Then it will just be the small aggrevating things such as setting up the throttle plates to open in sync, and setting up a couple of butterfly pieces and cable supports etc...
It's coming along though!
