ITB progress thread - FirebirdV6.com/CamaroV6.com Message Board
ITB progress thread
  • ITB progress thread
    Advance tech is dead...mine as well make a thread for this anyways so you guy can watch my slow progress hahaha....
    So this is what I got done today.
    Not the prettiest, but if it works that's all that matters...can work on aestetics later.
    So, so far I got the bottom mount base plate done (one that I will have bolt up to the holden manifold), and 4 of 6 throttle bodies...the other 2 throttles should be done soon. Then I can go on to making the two side mounting plates (plates that connect and hold the tb's in place)
    Then I pretty much need to wait until either A) I get a job, or B) I sell this second car so I can get some funds to buy my mandrel bent piping....after that it's a matter of welding it all together. Then it will just be the small aggrevating things such as setting up the throttle plates to open in sync, and setting up a couple of butterfly pieces and cable supports etc...
    It's coming along though!
    Re: ITB progress thread
    Looks pretty crazy, is there a upper piece and lower to it?
      What is this?!
      Wait, Is that a V6 or V8?
        Originally posted by ACiFiC View Post
        What is this?!
        Search... its around.
          What is this?!
          ITB setup
          Lower is the holden manifold itself, unmodded except for being ported...the upper portion is what you are seeing being built.
            i remember you talking about this before. nice to see something happening. keep updating, i wanna see this work for you. do you use the stock injectors and fuel rail?
            Team NoVa
              well, 36# injectors since thats what I have now...I'd like to use the stock fuel rail, but I can't remember if my previous research says whether or not it bolts up to the holden LIM...so I may need to modify, or possibly run a new rail...
                If you can't use the stock rail , just use a setup like ZZP's rail setup's. 36lb injectors are good to use and easy to tune they are like 33LB's on our pressure system. Mine were scaled from 32lb's to 33LB's then used PE to tune them in correctly.
                  ya, I think I used your advice steve to dial in my injectors actually...
                    The injectors dont fit into the tb's?
                    Team NoVa
                      they might...I havent looked into yet, but either way I have injector holes on the LIM I'd have to plug...plus I am not sure about space wise to run injectors and a rain ontop of the tb's...Im cutting it really close for space...
                      • Manimal
                        Coil springs
                        by Manimal
                        6 days ago
                      • Manimal
                        Newby here
                        by Manimal
